Delogo And Batch Processing, getting me started
MikesMovies
Posted: Nov 27 2013, 04:33 PM
Hi
I have used Vdub to remove a sensor spot from video I shot while on holiday.
Delogo being the function/filter employed.
I have used PICVideo MJPEG for compression.
I wondered if there is a batch option to process all the videos with the same filter?
Thanks
Altaf
Posted: Nov 27 2013, 05:49 PM
All necessary files (and only) in one catalog. You open the first file. You adjust as it is necessary, F4 < Edit < Process directory... You specify this catalog, after where to put and a car Autostart.
Все нужные файлы (и только) в одном каталоге. Открываете первый файл. Настраиваете как нужно, F4 < Правка < Обрабатывать папку... Указываете этот каталог, после куда складывать и авто пуск.
MikesMovies
Posted: Nov 28 2013, 08:17 PM
Thanks very much for that.
I have been using delogo to try and remove this dirt spot on the inside of my lens.
Let me explain.
Just got back from a holiday of a lifetime to Antigua with loads of great photos and video made with my Lumix TZ18.
Trouble is I have noticed that in the upper section of the frames it has a fixed error that kind of greys out the pixels.
Time for a new camera but how can I use Studio to remove this blemish?
If this were photos it would be easy to clone the pixels next to the error but I can't work out how to do this on video.
Here is a before and after video:
https://www.youtube.com/watch?v=Zw6jZinnrbw
and after I tried Vdub:
http://youtu.be/mvmORkvUcjc
While it works to a degree, when the scene is more detailed, such as looking at trees and shrubs, the dirt spot appears as a spot of transparent wavy lines.
Not sure what adjustment to make?
Any help would be most kind.
2 replies since Nov 27 2013, 04:33 PM Track this topic | Email this topic | Print this topic
