| Anon321 |
| Posted: Nov 3 2013, 02:26 AM |
I was trying to compress a Minecraft video I recorded with Fraps (60 FPS, full-size) with the "Microsoft Video 1" codec. The file size is 14.7 GB. I am using the 32-bit version of VirtualDub. I tried the 64-bit version, but it didn't solve my problem.
How do I fix this error? |
| Posted: Nov 3 2013, 11:42 AM |
If the problem is 'My file is huge' then it because you're using a codec that dates back to Widows 95 You'd be better off using x264vfw or XVid
x264vfw http://sourceforge.net/projects/x264vfw/files/
xvid http://www.xvid.org/ although I prefer this version "Xvid 1.3.2 x86 / x64 MTK & DivX profiles" as it has better options http://www.xvidvideo.ru/xvid-video-codec/x...le-release.html
Basic x264vfw settings can be found here http://forums.virtualdub.org/index.php?act...1157&hl=x264vfw
x264vfw is a more modern codec - smaller files for same quality, slower encode xvid is a bit older - larger files, faster, less cpu to playback than x264
| Posted: Nov 17 2013, 10:26 PM |
For the record, error -7 means the frame size isn't supported... but yeah, don't use Microsoft Video 1. It's probably even worse than FRAPS' own codec. |
