| athlonInside |
| Posted: Sep 7 2002, 11:25 PM |
Help. I have an MM100PCTV card and to run it on Win 2000 i downloaded the tweaked bt848 drivers. Then i downloaded Dscaler and the TV is GREAT!!!. To capture video, i downloaded virtual vcr and this sees Dscaler fine but then i needed Virtualdub to complete the package, so i downloaded this too. Now the nightmare begins. i open Virtualvcr and set it to record and up pops Dscaler with the TV on. Then the TV disappears and up comes Virtualdub. I cannot set it to see Dscaler!!. the files dTVdrv.dll, dTVdrvNT.sys and dTV95.vxd are no good as this is version 1.4 of Dscaler and I have the latest version 4.0. PLEASE can anyone tell me how to get this combination to work correctly, as they are all great programs and i want to use them all to do my capturing and editing.??? |
| avih |
| Posted: Sep 8 2002, 04:57 AM |
you mentioned "the tweaked bt848 drivers". could you be more specific?
i'll recommend btwincap from http://btwincap.sf.net + koepi's btwincap switcher from http://www.roeder.goe.net/~koepi/
cheers |
| athlonInside |
| Posted: Sep 8 2002, 10:43 AM |
The drivers in question were from http://www.iulab.com .The are bt848 drivers to enable any bt848 based card to run under Windows 2000/XP. Cant really say any more than that but i can see if copying the driver dlls etc into the virtualdub folder will help. |
