Audio Compression - Mp3 Problem, audio compression doesnt seem to work
Lewis
  Posted: Sep 4 2002, 08:46 AM
Hi there,
Ive got following problem.
I do capture some TV programs (through my TV tuner to my comp. to be precise) but the captured file is of course very big. So I want to encode it with VirtDub.
Its ok with video compression (I use Divx4 - fast motion codec) but when I also select audio codec (I usually try MP3) and then try to encode it (save it) nothing happens. Without audio compression it works but its obviously still too big.
So what amI doing wrong?
Ive heard that there are some problems with MP3 codecs, so is there any other audio codecs useable with similar compression/quality results?
Tnx
Lewis
SillKotscha
Posted: Sep 4 2002, 09:04 AM
smart Moderator
first pass: set audio to no audio, DirectStreamCopy/ video as you like
sec. pass: set audio to avi audio, FullProcessingMode and select your mp3 compression (NO DivX;-)audio!)/ and of course video as you know
install lame_acm you'll be satisfied
cheers Sill
ProfDrMorph
Posted: Sep 4 2002, 09:24 PM
There is no DivX4 Fast Motion but only DivX3.11 ;-) Fast Motion. Could please be precise about what you use? Anyway I don't think that the video codec you're using is causing any problems here.
As Sill said: install lame_acm
and no there's no alternative to MP3 if you use AVI files.
Neo Neko
  Posted: Sep 5 2002, 08:16 AM
VirtualdubMod Alpha tester
QUOTE (ProfDrMorph @ Sep 4 2002, 03:24 PM)
Well if you meant here as in his situation possibly yes. But here as in the board the definatly no. IIRC it is one of the verboten codecs. wink.gif
SillKotscha
Posted: Sep 5 2002, 01:55 PM
smart Moderator
it's so wicked to see, that nearly everyone is able to speak german...
esperanto... !!!
ProfDrMorph
Posted: Sep 5 2002, 08:18 PM
QUOTE (Neo Neko @ Sep 5 2002, 10:16 AM)
depends on which DivX codec he meant. Saying "DivX4 Fast Motion" isn't perferctly clear smile.gif
Neo Neko
Posted: Sep 6 2002, 01:27 AM
日本語ーガ 少し 分かれます
"Whoops! Page does not support UTF-8" ばか ばか ばか
6 replies since Sep 4 2002, 08:46 AM Track this topic | Email this topic | Print this topic
