| pete |
| Posted: Sep 1 2002, 01:01 AM |
Hi, I'm making a cs movie of myself playin and was wondering how you can do slow mo, and how to speed up the movie. Thanks, Pete |
| Asmordean |
| Posted: Sep 1 2002, 03:03 PM |
Video->Frame Rate->Change To X Frame Per Second
Where X is your desired amount. NTSC is 29.97fps, Pal is 25fps.
If you want to change the speed dynamically through the stream then Virtualdub probably isn't what you want. |
| avih |
| Posted: Sep 1 2002, 04:40 PM |
you can read avisynth's 'selectevery' command documentation. it will allow you to accelerate/deaccelerate your clips/parts of them. |
| ProfDrMorph |
| Posted: Sep 2 2002, 01:51 PM |
AFAIK many people making game movies ( Quake, Unreal Tournament, Counter-Strike ) use Adobe Premiere to add effects. Maybe you could test a trial version ( if there is one ) but I don't know if the program is worth it's money for making one movie......... |
