I Have The Right Codec But The File Won't Open
yuranidiot
Posted: Nov 22 2002, 09:46 PM
What do you do when you know you have the right codec for a file but it still won't open?
Posted: Nov 22 2002, 10:36 PM
jcsston
Posted: Nov 23 2002, 04:56 PM
Matroska Dev
When you open it try using the extended open options.
fccHandler: Why do you say that, I say smash it with a hammer and then reinstall Windows.
Use the Matroska file format
drizztcanrender
Posted: Dec 5 2002, 03:13 PM
Well what file is it?And what codec does it need to open?Usually the thing is that some other codecs you have in your pc may interfere with that.Try uninstalling some similar codec or reinstalling the one you think the file needs.Reinstalling windows is certainly not neccessary.
What's exactly the error that comes up when you try opening the file?
3 replies since Nov 22 2002, 09:46 PM Track this topic | Email this topic | Print this topic
