| kupsjon |
| Posted: Nov 20 2002, 11:00 PM |
Hi guys im new here and after a little help. i use TMPGenc to convert all of my video file to vcd and i always use virtual dub to seperate the wav file first and remove and sync errors. However recently i have come accross a few problems, I have no problem seperating the wav file from iether avi or standard mpg files. But i have started to find a problem when i dl an mpg that is ready to burn as a svcd. As my dvd player is old it doesnt understand svcd so i have to convert them to vcd and if i do this direct the sound goes well out of sync but i just cannot seperate the audio with virtual dub when i try to load it i just get "cannot determine the file type of...."
The file itself plays fine on my machine so i have the correct codecs to play it but it just wont be recognised by virtual dub. Is there some patch, codec for virtual dub i can get as i really want to keep using this programme as it is so effective.
Any help would be great.TIA
Jon |
| Neo Neko |
| Posted: Nov 20 2002, 11:58 PM |
VirtualdubMod Alpha tester
SVCD is MPEG2 Virtualdub can not handle it. But if you have experience frameserving DVD to Virtualdub then you can do the same with SVCD files. I just encoded Spirited Away with a recent Xvid dev build form a 3 SVCD set. I got it down to 1 CD with almost perfect quality.
