| DubbedOut |
| Posted: Nov 8 2002, 12:32 AM |
OK what's up guys. I have a ton of codecs available on my system (I really don't know where most of them came from) .. What I am hoping to do is find the best 4-5 codecs of the lot, and then test them out. I've been having some audio sync problems capturing segmented files to Divx.. And I think Divx is the reason. Here's what I do:
Capture to segmented AVI 352x480 Framserve to TMPGEnc Output as Mpg2 1/2 DVD (352x480) Author & Burn 2 movies per DVD
Given those settings, plz rate the codecs in your experience from BEST to worst in terms of file size & quality. File size means for a 2 hour movie, the total size doesn't go beyond 30GB. Quality means non-blocky and it would look really good encoded to Mpeg-2.
Codecs List: (none) Full Frames Uncompressed WMF Windows Media Format DV Video Encoder Indeo Video 5.04 Intervideo MPEG Video Encoder Indeo Video 5.06 Ligos GoMotion DV to MPEG Arcsoft MPEG-2 Writer Picvideo Mjpeg Compressor Picvideo Lossless Jpeg Compressor VDOnet VDOWave Cinepak Codec by Radius Microsoft Video 1 Microsoft RLE Huffyuv v2.1.1 Divx 5.0.2 Codec Microsoft MPEG-4 Video Codec V1 Microsoft MPEG-4 Video Codec V2 Microsoft MPEG-4 Video Codec V3 VFAPI Reader Codec 1.03 DVSoft |
| Neo Neko |
| Posted: Nov 8 2002, 02:41 AM |
VirtualdubMod Alpha tester
| QUOTE (DubbedOut @ Nov 7 2002, 06:32 PM) | OK what's up guys. I have a ton of codecs available on my system (I really don't know where most of them came from) .. What I am hoping to do is find the best 4-5 codecs of the lot, and then test them out. I've been having some audio sync problems capturing segmented files to Divx.. And I think Divx is the reason. Here's what I do: |
Divx or any highly compressed format is a bad choice for capture.
| QUOTE (DubbedOut @ Nov 7 2002, 06:32 PM) | | WMF Windows Media Format |
Snowball's chance in hell durring a heatwave for that to work well.
| QUOTE (DubbedOut @ Nov 7 2002, 06:32 PM) | | DV Video Encoder |
Reasonable/quality size. Speed varies. But it is hard to edit.
| QUOTE (DubbedOut @ Nov 7 2002, 06:32 PM) | | Indeo Video 5.04 |
Very lossy codec. Bad for capture.
| QUOTE (DubbedOut @ Nov 7 2002, 06:32 PM) | | Indeo Video 5.06 |
Ditto.
| QUOTE (DubbedOut @ Nov 7 2002, 06:32 PM) | | Picvideo Mjpeg Compressor |
It is excelent. I use it and morgan MJPEG as well. They are both fast, offer decent compression, and good quality. I generally get about 2:30 in 20Gb of space.
| QUOTE (DubbedOut @ Nov 7 2002, 06:32 PM) | | Picvideo Lossless Jpeg Compressor |
SLOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOW. Good quality. But not suited for capture.
| QUOTE (DubbedOut @ Nov 7 2002, 06:32 PM) | Cinepak Codec by Radius Microsoft Video 1 Microsoft RLE
Stop it! Now you are making me nostalgic for Windows 3.11. They are very old and bad quality not to mention somewhat slow in some cases.
| QUOTE (DubbedOut @ Nov 7 2002, 06:32 PM) | | Huffyuv v2.1.1 |
The best. But be prepared to pay in HD space. Though 1/2 to 1/4 the space needed for uncompressed.
| QUOTE (DubbedOut @ Nov 7 2002, 06:32 PM) | | Divx 5.0.2 Codec |
To lossy and CPU intensive.
| QUOTE (DubbedOut @ Nov 7 2002, 06:32 PM) | Microsoft MPEG-4 Video Codec V1 Microsoft MPEG-4 Video Codec V2 Microsoft MPEG-4 Video Codec V3
They can't pass muster for simple encoding. Capture is out of the question.
| QUOTE (DubbedOut @ Nov 7 2002, 06:32 PM) | | VFAPI Reader Codec 1.03 |
Not actually a codec. But slow and outdated still.
| Posted: Nov 8 2002, 04:11 AM |
My vote for the top five codecs that everyone should have:
1) DivX 5.0.2 (the best) 2) PicVideo MJPEG (the fastest) 3) Huffyuv (lossless) 4) On2 VP3 (good, but slow) 5) Microsoft MPEG-4 v3 (when all else fails)
I ordered my list based on how often I use the codec. Also, I should say that I haven't tried many of the other codecs out there (XviD, DV, etc.) so I'm not qualified to rate them.
| DubbedOut |
| Posted: Nov 8 2002, 02:21 PM |
Great, thanks for the help so far. And to add one more question, are there any really good codecs to capture with that are not on the list? |
| BaronVlad |
| Posted: Nov 15 2002, 06:45 PM |
Terrorhörnchen
Leadtech and Morgan MJPEG are not in the list, but they are very good, if you have a VERY FAST system but not enough diskspace for using Huffyuv.
