Audio Compression Manager (acm) Failure On Progres
Wiesmeier
  Posted: Apr 14 2003, 05:22 PM
Hello,
the error "Audio Compression Manager (ACM) failure on progress" appears after about 5min into encoding.
It only happens when the mpeg3-layer sampling rate is over 64kBit/s below that the encoding works properly???
Can somebody help me
system WIN XP /AMDXP1800
Virtualdub 1.1.15 (it also appeard in 1.1.14)
divx 5.0.2
radium codec 1.263
thanx
Cerberus
Posted: Apr 15 2003, 01:37 AM
I dont use that codec. But ive had results with the Fraunhofer PRO acm codec or the LAME ACM.. just serch in google to find a site with it on
wink.gif hope it helps
Wiesmeier
  Posted: Apr 15 2003, 05:57 PM
I tried it with lame... -> same result
Audio Compression Manager (ACM) failure on compress
shit!!
Wiesmeier
  Posted: Apr 15 2003, 07:38 PM
now I removed the radium codec from the system and it works -> almmmoooooossst:
1pass method:
The decoding works until the end of the file and then the message
"an out-of-bound memory access (access violation) occured in module 'LameACM'
-> result file usable
2pass method/first pass:
at about 85% through the first pass the same error message occurs and the encoding stops -> result file unuseabel (of course)
3 replies since Apr 14 2003, 05:22 PM Track this topic | Email this topic | Print this topic
