| wiebe |
| Posted: Sep 24 2002, 03:16 PM |
I have a low cost firewire card from Dynalink (+win2k, ntfs), and want to capture DV.
Using Virtualdub captures, bur I can't use it. This problem is described on the project site, but is there a way to solve it?
Ulead SE is included with the card, but DV files captured with Ulead can't be used in Virtualdub.
Any suggestions? |
| wiebe |
| Posted: Sep 24 2002, 08:13 PM |
On http://www.siig.com/knowledge/10050304.HTM I read
| QUOTE | SIIG 1394 cards work with any software that supports DV AVI Type 1 or Directshow.
SIIG 1394 cards do not work with Adobe Premiere 5.x. Adobe Premiere 5.x supports DV AVI Type 2 or Video for Windows. We will not have a CODEC to support Type 2. |
Is there a way to work around this? Translate? |
| drizztcanrender |
| Posted: Sep 26 2002, 09:55 PM |
I think,not sure,that link2 might do that.Why don't you try it?Go here:
http://www.videotools.net/uk/intro2link2.p...8afc84fde953c60 |
