Problems With Divx 503 Pro, encoding loss
WookieSM
  Posted: Apr 3 2003, 02:53 PM
i recently started to use divx 503pro for encoding but every thing i have encoded has been fine for bout 20mins then it gose all blocky then its ok again for a bit then all blocky again wink.gif if u can help please do ive gone bak to 502 for now as this seems to work fine wacko.gif
Cyberman
Posted: Apr 17 2003, 11:58 AM
I´m having troubles with the Divx 5.0.X too(mainly because I till yet only used a VERY old DivX codec).
Anyway, my guess would be that the codec might "overlook" a scene change. Could it be that?
Matroska/MKV ?
endorphin
Posted: Apr 17 2003, 02:17 PM
DivX 5.04 "Schizo" Beta has been made available, and fixes many bugs in 5.03. It's not guaranteed to fix everything... I repeat, beta... but worth a try.
DivX 5.04 Beta
It also has an interesting tool ("Electrokompressiongraph") for directly/manually controlling bitrate modulation if you choose, during Nth-pass encoding.
2 replies since Apr 3 2003, 02:53 PM Track this topic | Email this topic | Print this topic
