| marys |
| Posted: Apr 1 2014, 05:59 PM |
http://i.imgur.com/agTJdYo.png
The picture becomes gray and distorted. Before it worked before I delete by mistake codes'' ffshow and codec''. But now, some videos don't work and I can't find solutions. *sorry for my english*
thank you |
| Abrazo |
| Posted: Apr 1 2014, 06:51 PM |
If you are sure that it goes about the H.264 codec, then the most simple solution for you will be to install x264vfw that you can find here: http://sourceforge.net/projects/x264vfw/files/
The ffdshow try-outs are here: http://sourceforge.net/projects/ffdshow-tr...ial%20releases/ (if you should choose for this second solution, then via "VFW configuration" you will have to enable the H.264/AVC decoder)
Take care to select either the classic 32-bit or either the 64-bit version, corresponding to the xx-bit installation of your VirtualDub.
Good luck. |
| marys |
| Posted: Apr 1 2014, 08:45 PM |
I downloaded both.
But still not working. I don't understand. The video was converted to AVI (MKV to AVI). It worked before. : S |
| Posted: Apr 1 2014, 09:39 PM |
That's because the files width is not a multiple of 4 You can probably open it correctly with the directshow or ffmpeg plugins
-- VFW codecs are usually stricter about getting the source files being in spec
| marys |
| Posted: Apr 2 2014, 01:18 AM |
I don't understand, it still doesn't work and I downloaded it! It's really strange. |
| Abrazo |
| Posted: Apr 2 2014, 07:11 AM |
In VirtualDubs "Open video file"-dialogbox you must first select the AVI that you want to open. Secondly you have to choose in the "Files of type:" for the inputdriver that you like to use: - Audio/video interleave - FFMPeg Supported Files - DirectShow input driver
Please try these, one by one... |
| marys |
| Posted: Apr 2 2014, 05:18 PM |
I opened, but nothing. I don't think of having what you say. The version of Virtualdub is 1.9.9. :S
http://i.imgur.com/TCa4YzR.png
http://i.imgur.com/Gf0umf3.png |
| Abrazo |
| Posted: Apr 2 2014, 06:20 PM |
You can try with:
DirectShow inputdriver: - Download : http://www.virtualdub.org/beta/DShowInputD...Driver-0.93.zip - Installation : unzip the "DShowInputDriver.vdplugin" to the plugins32 subfolder of your VirtualDub installation.
FFMPeg inputdriver: - Download : http://sourceforge.net/projects/virtualdub...latest/download - Installation : unzip the "FFInputDrive*.vdplugin" to the plugins32 subfolder of your VirtualDub installation + unzip the *.dll files to a subfolder ffdlls within the plugins32 subfolder.
Now you should find them in the "Files of type:" |
| raffriff42 |
| Posted: Apr 2 2014, 07:51 PM |
>The version of Virtualdub is 1.9.9. Try VirtualDub 1.10.4, 32 bit, I think it's required.
For FFMPeg inputdriver (it's awesome), here is a post I made on another forum showing how to install and use it.
If the plugin is installed correctly and you still have a problem, please post a MediaInfo report on your problem video. |
| marys |
| Posted: Apr 3 2014, 04:41 AM |
seems to work now. The video opens normally
Thank you both for your help |
| Abrazo |
| Posted: Apr 3 2014, 08:46 PM |
@raffriff42 Thanks for helping, I was not aware of the fact that latest versions of FFMPeg inputdriver do not show up anymore in VirtualDub 1.9.9 and 1.9.11. VirtualDubs 1.9.11 Log-file tells me: Error loading plugin "FFMPeg" from module FFInputDriver.vdplugin: Plugin requires a newer input API version (v4 > v2). A little strange ... (maybe dloneranger can tell us something more about this ?)
@marys If you should come back to this thread, please do us a favor ... and tell us what you did exactly to be able to open your video ... - Did you install VirtualDub 1.10.4 or later ? - Did you install FFMPeg inputdriver and / or DirectShow inputdriver ? - With which one of these two did it work ? - When you look into File > File information... which video-decoder was finally used to correctly open your video ?
All this information can be of interest to other visitors of this forum.
Please do not just say : now it works. These words do not tell us much. Sorry to say. |
| Posted: Apr 3 2014, 09:16 PM |
| QUOTE | Thanks for helping, I was not aware of the fact that latest versions of FFMPeg inputdriver do not show up anymore in VirtualDub 1.9.9 and 1.9.11. VirtualDubs 1.9.11 Log-file tells me: Error loading plugin "FFMPeg" from module FFInputDriver.vdplugin: Plugin requires a newer input API version (v4 > v2). A little strange ... (maybe dloneranger can tell us something more about this ?) |
Support for colourspace 709/601 and fullrange/limited requires sdk v1.2, and that requires virtualdub v1.10.1 Hopefully having those outweighs the blocking of earlier virtualdub versions
