| cyberlogos |
| Posted: Mar 2 2014, 07:11 PM |
To add subtltles in .ssa the Xvid codec is recommended but it is not found on the VirtualDub Menu Video/Compression, question is how to add it to the compression options ? Instructions appreciated ! |
| Posted: Mar 2 2014, 07:27 PM |
Go to http://www.xvid.org/ Click on the 'get the latest version of the Xvid codec for your platform' link Download and install it Start virtualdub
| evropej |
| Posted: Mar 5 2014, 04:36 PM |
Make sure you are using 32 bit version software. 64 bit version requires 64 bit compression codecs. |
