12-bit Mjpeg Inside Virtualdub, MJPEG
zcream
Posted: Dec 4 2013, 01:52 PM
I am going to use a USB3 MVC in 12-bit 4:2:2 RAW mode.
It has a DirectShow driver.
The JPEG spec support 12-bit 4:2:2 JPEG files.
Does the MJPEG codec inside Virtualdub support writing 4:2:2 12-bit MJPEG files ?
I think VD is still 8-bit in RGB colorspace. However, I am hoping that the DirectShow driver can supply 10-bit 4:2:2
or even 12-bit 4:2:2 and then this can be captured within VD.
If I turn on Direct Stream Copy - perhaps the resolution and data is preserved.
raffriff42
Posted: Dec 4 2013, 10:56 PM
Virtualdub is limited to 8-bit, as you can confirm by looking at all the available pixel formats under Video, Color Depth.
I can open deep color video (tested ProRes 10-bit and FFV1 10-, 12- & 16-bit) using the FFInput plugin, but the video is converted (truncated, I think) to 8 bits. Direct stream copy does not work.
I gather VfW itself is limited to 8 bits max, so there's not much chance of an upgrade.
raffriff42
Posted: Dec 10 2013, 08:54 PM
I stand corrected.
http://www.virtualdub.org/blog/pivot/entry.php?id=268
v210 and NV12 are now supported by the blitter engine and can be selected as input and output formats.
EDIT - more information:
QUOTE (phaeron @ Feb 12 2010, 04:25 AM)
... support is fairly limited. What VirtualDub's v210 support enables is:
[*] Selecting v210 as a pass-through format between codecs.
[*] Displaying 10-bit/channel video, if Direct3D display mode is enabled with "high precision" on. In this case, the 30-bit data is dithered down to 24-bit.
Processing is still limited to 8-bits/channel -- any filtering options will force a downconversion.
Posted: Dec 28 2013, 09:54 PM
Correct, VirtualDub itself doesn't support processing 10-bit or 12-bit per component data.
However, it can pass that data onto a codec without downconverting it, so if you have a codec that can take 12 bpc data directly, VirtualDub can pipe it through.
3 replies since Dec 4 2013, 01:52 PM Track this topic | Email this topic | Print this topic
