| mattad |
| Posted: Oct 31 2013, 10:14 AM |
Doies VD work also with DirectShow codecs or only with VfW ?
In other words: If I have the choice to install DirectShow or VfW should I install/use DirectShow?
Matt |
| Dstruct |
| Posted: Oct 31 2013, 12:47 PM |
http://forums.virtualdub.org/index.php?act...=ST&f=7&t=15093 |
| Posted: Oct 31 2013, 02:00 PM |
Depends on if you need to encode with that codec DirectShow codecs can be used with the DirectShow plugin but only for decoding If you need to encode you'll need the VFW type (unless you're using the external encoder options)
