| Wim |
| Posted: Apr 23 2013, 07:11 PM |
I am a user of VirtualDub 1.10.3 32 bit on a W7 laptop and on a W7 destop. On the laptop I can find all codec’s via Video>>>Compression. On my desktop there is no codec present at all. Any idea how I can bring the standard codecs into VD? Help will be highly appreciated, Wim |
| Posted: Apr 23 2013, 07:46 PM |
You might want to check your registry for empty codec values http://forums.virtualdub.org/index.php?act...=ST&f=3&t=14258
| Wim |
| Posted: Apr 23 2013, 08:46 PM |
Thanks, I found the "vidc.uldx" also and removed it. VD 1.10.3 32 bit version crashed and can not be brought to life again. But the 64 bit version shows the codec's! Could you tell me how to repair the 32 bit version, a new download did'nt bring the solution. Wim |
| Posted: Apr 23 2013, 08:53 PM |
The 32bit registry keys are inside other keys called 'Wow6432Node' eg HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft.......... HKEY_CURRENT_USER\Software\Wow6432Node\Microsoft.............
| Posted: Apr 23 2013, 09:00 PM |
Also, check the drivers.desc keys
If there's an entry there that doesn't match any of the ones in drivers32 then see if deleting that helps (always make a copy or export the registry first)
eg drivers32 -> vidc.lags=lagarith.dll drivers.desc -> lagarith.dll=Lagarith lossless codec [LAGS]
| Wim |
| Posted: Apr 25 2013, 10:03 AM |
I’m not experienced enough to work in the register so that I can follow your suggestions. After the crash of the 32 bit version I returned to the original situation because I need the 32 bit version really. What I’m looking for is this package of codec’s in VD: https://dl.dropboxusercontent.com/u/1578917...Compression.png There are also other codec’s on my computer including Matrox. Is there a chance that a conflict between codec’s prevents VD to accept the Matrox VfW codec’s ? Wim |
| Posted: Apr 25 2013, 03:10 PM |
Nothing I've ever heard of no No codecs showing is normally the 'empty entry' problem in the registry or quartz.dll has been unregistered
| Wim |
| Posted: Apr 25 2013, 03:18 PM |
Thanks, and is there a possibility to check whether quartz.dll is registered. If yes, is that something I could do? Wim |
| Posted: Apr 25 2013, 03:29 PM |
You have 64bit os?
Assuming so, in the start menu, type cmd right click on it and 'run as administrator'
In the command prompt type cd \windows\syswow64 regsvr32.exe quartz.dll
you should get a popup message, then you can close the prompt
| Posted: Apr 25 2013, 03:32 PM |
If you could you post screenshots of regedit, showing
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows NT\CurrentVersion\drivers.desc HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows NT\CurrentVersion\Drivers32
or export the keys and post them here, we check them for error
Does virtualdub show its crash dialog? You should be able to save the log and post that as well
| Wim |
| Posted: Apr 25 2013, 03:50 PM |
A crash dialog was not shown. I give you the screenshots of the two keys you mentioned and hope you can finf a bug. It’s weird that on my laptop VD shows exactly what I need but on the desktop there is uncompressed only. Good luck, Wim https://dl.dropboxusercontent.com/u/1578917...rivers.desc.png https://dl.dropboxusercontent.com/u/1578917...s32%20pag.1.png https://dl.dropboxusercontent.com/u/1578917...%20pag.%202.png |
| Posted: Apr 25 2013, 05:39 PM |
Hmmmmmm, can't see anything weird in them
You could try deleting the Virtualdub registry key (don't think it'd help though) HKEY_CURRENT_USER\Software\VirtualDub.org
Last thing I can really think of is to run ProcessMonitor and have it track what's being loaded You'd start it, then start virtualdub When virtualdub crashes, stop the recording and save it. Then upload it somewhere, it might give a clue, like the last codec loaded
http://technet.microsoft.com/en-us/sysinte...ernals/bb795533
| Wim |
| Posted: Apr 25 2013, 07:43 PM |
Deleting the key VirtualDub.org did not change things as you expected. During the ProcessMonitor run VD did not crash. Since the whole list is ca 640 MB, I took some screenshots. Perhaps is this an indication whether it’s worth to send the whole list and then everything also not VD data. https://dl.dropboxusercontent.com/u/1578917...917/pag%201.png https://dl.dropboxusercontent.com/u/1578917...917/pag%202.png https://dl.dropboxusercontent.com/u/1578917...917/pag%203.png Do you have any idea whether a clean W7 installation would solve this bug? Thank you for your help, regards Wim |
| Posted: Apr 25 2013, 08:07 PM |
Oh, a clean install always fixes problems :-) All kinda depends on just how much stuff you'd have to reinstall after though It can be a total pain, but may be easier than trying to track the problem down
The screenshots don't really show anything interesting btw, you can right click on .exe's in the list (on the left) and exclude any process you're not interested in to make a saved log smaller I was hoping vdub would crash and the last few 100 entries might have shown something useful
