Missing Codec
Miyu_Zangetsu
Posted: Jan 21 2013, 10:35 PM
Hi.
I have already downloaded the last version (1.9.11, 64-bit) and I'm installed the necessary codecs and plugins (mkv, mp4)
but I read the written (Missing Codec/ Missing Codec mp4v/ Missing Codec avi1)
I do not know how to sove the problem since I have already installed the codec.
Posted: Jan 22 2013, 07:40 PM
When installing VirtualDub 64-bit you must also install the 64-bit versions of inputdriver plugins and codecs.
The inputdriver plugins like Matroska and QuickTime relay on installed (Video for Windows) VFW version of video-codecs.
The most easy way to make them available is to install ffdshow, that you can find here:
> http://sourceforge.net/projects/ffdshow-tr...eleases/64-bit/
After installation of ffdshow you will have to 'enable' the needed codecs via the "VFW Configuration" menu-item.
For Audio-decoding you will also have to install ACM-codecs like AAC and AC3, that you can find at the same place as the inputdriver plugins:
> http://gral.y0.pl/~fcchandler/
> http://forums.virtualdub.org/index.php?act...=ST&f=7&t=19488
On the other hand you have also the possibility to install the "DirectShow" inputdriver plugin for VirtualDub.
This means that, when you are able to play a videofile via Windows Media Player, then you should be able to open it in VirtualDub via de DirectShow plugin that relays on the DirectShow version of codecs on your pc.
> http://forums.virtualdub.org/index.php?act...=ST&f=7&t=15093
1 replies since Jan 21 2013, 10:35 PM Track this topic | Email this topic | Print this topic
