Filters Only Enabled In Full Processing Mode
jsallen
Posted: Dec 10 2011, 04:05 PM
The Filters menu item is grayed out and I find that I am able to use Deshaker (including the second pass which produces the output file) only in Full Processing Mode, producing enormous files. Then I have to run conversion to create a compressed file. Is there a way around this?
Posted: Dec 10 2011, 04:07 PM
Filters only work in full processing mode
To make a smaller file, choose a compressor from the compression menu and configure it
jsallen
Posted: Dec 10 2011, 04:32 PM
So, you are saying that i have to run another pass, unfiltered, to create a smaller file?
ale5000
Posted: Dec 10 2011, 04:45 PM
No, do it in the same pass.
New VirtualDub forum
jsallen
Posted: Dec 10 2011, 08:38 PM
OK, now I am finding that I can use a compressor in full processing mode. The problem i had was with VirtualDub's dumping presets when closing and reopening it.
4 replies since Dec 10 2011, 04:05 PM Track this topic | Email this topic | Print this topic
