Yuy2 Error Problems, Loading a .TS video causes YUY2 error
Oldmartian
Posted: Sep 19 2011, 11:30 PM
After I load a .TS file I click the Input play button and get an error reading:
The decompression cocec decompresses to an RBG format.  This is very unusual.  Check that any "Force YUY2" options are not enabled in the codec's properties
I've looked in Options | Preferences and can only find one instance under AVI an option to uncheck directly decode uncompressed YCbCr (YUY) sources but checking or unchecking has not effect: the error shows up when I load the *.MTS file.
The input window shows the first frame of the video, but trying to play the video is where I get the error.
I also cannot load *.MTS files. The .MTS is not a listed file extension so I'm using "List all files" in the file input box. When I choose the .MTS file I want to load I get this error:
The file "F:\V-dubTest2.MTS" is of unknown or unsupported file type.
Somehow I think the errors are connected to the same problem(s).
I'm running a W7 machine with plenty of horsepower and lots of RAM. I'm sure the problem lies somewhere between the keyboard and the chair.
Thanks
OldMartian
"Women and cats will do as they please, and men and dogs should relax and get used to the idea."
- Robert A. Heinlein
0 replies since Sep 19 2011, 11:30 PM Track this topic | Email this topic | Print this topic
