Problem With Mov Files, Can playback MOV, but becomes grey
raydream
Posted: May 7 2011, 01:35 AM
Hi there,
I am experience problem opening MOV file recorded from Canon EOS 7D.
Basically, the video can be played, sound is okay. However the video will turn periodically to grey in playback. When I export, the grey region remains.
I had uploaded a video captured while playback in virtualdub here:
http://www.youtube.com/watch?v=w7ThCYo5LAw
Please help!
I had tried it on WinXP and Win7, the problem remains.
Rgd.
Placio74
Posted: May 7 2011, 08:29 PM
VideoAudio
If You use QuickTime import plugin, tried to set (in 'extended' import options when opening a file) different video decoder mode than default (ICM Decomp or MoviesTask)?
Or... if You use DirectShow import driver problem does not occur when playing in a DirectShow player (such as WMP)?
raydream
Posted: May 8 2011, 05:08 AM
Hi thanks for response! Really needed help here.
Yes I used MOV import plugin, YES! A moviedecoder mode works in the extended options! Thanks!
And to answer your other question, DirectShot got no problem when I play it with MediaPlayerClassic.
OMG EXTENDED IMPORT OPTIONS! IT WORKS! Now is there way I can set it as default when I open MOV files?
Placio74
Posted: May 8 2011, 03:05 PM
VideoAudio
QUOTE (raydream @ May 8 2011, 07:08 AM)
... Now is there way I can set it as default when I open MOV files?
After selecting a video decoder mode, click Save to Quicktime.ini option.
3 replies since May 7 2011, 01:35 AM Track this topic | Email this topic | Print this topic
