Portable Vd Codecs (plugin)?
tanker
  Posted: Feb 8 2011, 05:57 PM
I installed the FLV plug in by fccHandler and also put it in the plug in directory of the portable version. It seems to work fine.
I also loaded the x264 codec on my desktop system.
Are there any plug in versions of codecs that can be used by VD, in particular the portable version. VD is great but I would like to be able to take it with me. I can run things off my thumb drive at work but I can't install.
Am I looking in vane for plug in codecs? In a search on this board I found some one mention that it would be nice to have plug in codecs that would eliminate the need to install a butt load of different codecs. Just plug in what you need. However that message was a couple years old. Don't know if anything has developed since then.
I once installed ffdshow on my system at home but I just didn't like the way it incorporated itself in to all my different media programs. Just a personal preference.
Thanks All
0 replies since Feb 8 2011, 05:57 PM Track this topic | Email this topic | Print this topic
