| sharebear |
| Posted: Dec 31 2010, 11:27 AM |
Hello!
I used to use Virtual Dub every day, simply to cut files. I recently had to reformat my computer....and ever since, I can't use Virtual Dub at all. Nothing works because all of my codecs are missing. I tried to follow through the forum with the codec problems others are having, but it hasn't helped because we aren't having the same problems so I'm still missing stuff.
I installed this ---> https://sourceforge.net/projects/ffdshow-tryout/ but I don't really know what to enable and disable....
What should I do? Any assistance would be great! Thank you! ^^b |
| ale5000 |
| Posted: Dec 31 2010, 12:10 PM |
Go on the VFW configuration (yellow icon) of ffdshow-tryout and enable the codec that you need. Open the video file with MediaInfo to see what codec is needed to be decoded.
