| Barnister |
| Posted: Aug 20 2010, 12:56 PM |
I've no installed http://forums.virtualdub.org/index.php?act...=ST&f=3&t=19046 these codecs, but I've got the problem that ffdshow - audio, does nothing.
Particularly the "Volume" option in Audio Decoder Configuration from ffdshow. I use Media Player Classic.
Anyone ab le to help me? |
| Posted: Aug 20 2010, 02:08 PM |
Is media player classic using ffdshow? By default it uses it's own filters
If you play a video in it, right click on the video and open the 'filters' item in the drop down menu If ffdshow audio's filter isn't listed then mpc is not using it
To enable ffdshow's filter, go to mpc's menu->view->options Then select 'internal filters' on the left. You'll see a large list on the right of mpc's own filters - you can turn each one on/off as desired Close mpc and open the video again for changes to take effect
| Barnister |
| Posted: Aug 22 2010, 06:41 PM |
cheers! Thanks! |
