Can't Decode Ac3 Audio From A Dvd
pehache
Posted: Feb 17 2010, 07:07 PM
Hello,
I have Virtualdub 1.9.8 installed, with a bunch a plugins, including the mpeg-2 and ac-3 input filters.
I open a .VOB file from a DVD (which is supposed to contain AC-3; at least ffmeg reports "liba52" for the audio stream), and when I try to save it as AVI (video compressed to mpeg4 with ffdshow, audio to mp3 with Lame) I get the error message :
No audio decompressor could be found to decompress the source audio format (source format tag: 2000)
Any idea ?
Thanks,
Placio74
Posted: Feb 17 2010, 07:54 PM
VideoAudio
AC-3 plugin is only for importing AC3 audio from external file.
Install AC-3 ACM Codec.
pehache
Posted: Feb 17 2010, 08:34 PM
What do you mean by "external file" ?
fredgiblet
Posted: Feb 17 2010, 09:03 PM
QUOTE (pehache @ Feb 17 2010, 08:34 PM)
If you had a video file and a separate audio file that you wanted to put in the video file.
vid.avi+aud.ac3 into vid2.avi for example
DarrellS
Posted: Feb 17 2010, 09:52 PM
I assume that AC3ACM did not work?
Could you copy and paste a MediaInfo text file of the VOB that you are trying to convert?
pehache
Posted: Feb 18 2010, 07:26 PM
Actually the AC3ACM codec worked.
I was just unsure about what were the "external files"...
The Windows codec world is still a big mystery to me biggrin.gif (mpeg-2 input video requiring a VD plugin while ac-3 input audio requires a windows codec...)
Anyway, it works, and it's all what I needed, thanks !
gottogo99
Posted: Apr 20 2012, 03:30 AM
Hi, I joined just to reply to this old thread. I was having the exact same problem: did not understand why the AC-3 plugin would not allow me to play a VOB file from a DVD with AC-3 audio. After all, the MPEG-2 plugin allowed me to open the file. I installed the AC-3 ACM Codec and all is well. I wish the difference was better publicized.
Thanks for the great free software, btw.
Berk
Posted: May 22 2012, 01:45 PM
Where can I find the AC3 plugin? Thanks. I installed the AC3ACM codec but when I try to add ac3 audio to my avi, I get an unsupported audio file error message.
Posted: May 22 2012, 07:27 PM
You can find this plugin (among others) on fccHandler's stuff:
http://home.comcast.net/~fcchandler/index.html
8 replies since Feb 17 2010, 07:07 PM Track this topic | Email this topic | Print this topic
