| len_hartley |
| Posted: Dec 19 2002, 06:54 PM |
I wonder why VirtualDub doesn't support DV-AVI, Type 1 (i.e. the type of AVI file that so many people are capturing from the DV camcorder).
It is possible to get VDub to work with DV-AVI, but you have to get the MainConcept (or Panasonic) Codec. Even then, it is using the older Video-for-Windows (DV AVI, Type 2) standard which is more prone to audio synch problems. It also requires the extra step of converting from your DV-AVI from Type 1 (that you captured) to the more error-prone Type 2 first.
Is there something fundamentally difficult about adding DV AVI, Type 1 support? Are there licensing issues/costs?
| S_O |
| Posted: Dec 19 2002, 08:22 PM |
Vdubmod Alpha Testing Team
There aren´t any specs how the audio is stored in the type-1 avi, but there is a very good way to get virtualdub read the audio. Remux the avi with GraphEdit:
| CODE | ----> dvtype1.avi -> Avi Splitter -> DV Splitter - | | AVI Mux -> File Writer ----> |
The file won´t be bigger and without any loss. It can be perfectly read by VirtualDub or any other software. |
| len_hartley |
| Posted: Dec 23 2002, 08:38 PM |
Virtually all major products work with DV-AVI, Type-1 (video editors, TMPGEnc, WinDVD, Win Media Player, even audio editors). I thought that the decoder that comes with modern versions of Windows did the work for these products ... products just need to tie into the codec.
The best explanation that I have seen is here: http://groups.google.ca/groups?selm=3e009e...t&output=gplain and http://groups.google.ca/groups?hl=en&lr=&i...news.jersey.net
