| Flood |
Posted: Aug 29 2002, 06:47 AM |
Hi.
Odd problem I am experiencing, which wasn't happening until today.
Running xp pro, capturing with vdub and huffyuv (lastest of both). The codec shows up correctly in the device manager and in dxdiag, however it isn't available on the list when selecting video compression from inside vdub.
I have uninstalled and reinstalled the codec several times, to no avail. Anyone else ever experienced this? |
| avih |
| Posted: Aug 29 2002, 03:55 PM |
there are 2 options:
1. the video formay doesn't match huffyuv. 2. it's a known xp problem that sometimes codecs 'dissappear' spontaniously. there's a simple registry fix for that. check out the forum on http://forum.doom9.org and search for 'disappear codec xp*' i think you should find the link. |
| Flood |
| Posted: Aug 29 2002, 05:41 PM |
I tried a number of searches on doom9's forums, including the one you gave me, but wasn't able to find anything.
My source is 640x480 interlaced, 29.97fps, YUV2. Additionally, I've noticed that the only PicVideo encoder that shows up is the MJPEG one, even though I have both the wavelet and lossless codecs installed as well, so I think there must be something else going on here (such as the potential bug you mentioned?)
Thanks! |
| avih |
| Posted: Aug 29 2002, 08:44 PM |
http://forum.doom9.org/showthread.php?s=&t...odec+dissapp%2A |
| Flood |
Posted: Aug 29 2002, 09:39 PM |
Outstanding!
That was it, thanks so much for your assistance, I can see all the codecs again. |
| NoodleHut |
Posted: Feb 21 2003, 09:27 AM |
Thank you thank you thank you thank you!!!! I've been sitting with the same problem for quite a while now not having any idea what was wrong. Now it's back to capturin' and compressin' as usual! |
