| stephanV |
| Posted: Jul 30 2004, 10:26 PM |
Well, the topic title just pretty much says it all... I can't think of a reason why not, but it feels unintuitive. (considering there probably arent any ACMs for them)
Just a question out of interest.
| Wilbert |
| Posted: Jul 30 2004, 10:35 PM |
mpeg1 layer II is possible (dunno about layer I). See AviSynth FAQ (and get the ACM codec):
http://www.avisynth.org/Section+2%3A+AviSy...ameserving#q2.9
Wilbert |
| stephanV |
| Posted: Jul 30 2004, 10:57 PM |
ah thx
layer I should be possible too (cant see why not). a MP3 decoder should also be able to decode layer I and II but the problem is they dont share the same audio tag
| Posted: Jul 31 2004, 04:54 AM |
For some strange reason, the Fraunhofer codec will only decode Layer III, but that's OK because Windows has its own internal support for Layers I and II. IIRC both work fine in AVI files, as long as you use a DirectShow player (like Windows Media Player).
My VirtualDub-MPEG2 used to allow Direct Stream Copy of MPEG-1 Layers I, II, and III from MPEG files into AVI files, but I just discovered that the current version has this feature disabled! (Instead, it decompresses the audio and sends it along as raw PCM.) I don't remember why I disabled it, but there must have been a reason. I'll investigate...
| Posted: Jul 31 2004, 09:06 AM |
AVI files with MPEG-1 layer II streams are indeed possible and are seen in the wild; the WinDVD Creator software that comes with the Plextor PX-M402U generates them. I haven't yet coded up support for decoding them. |
| i4004 |
| Posted: Jul 31 2004, 03:37 PM |
this reminds me of my recent mpeg4 versus mpeg1/2 shootout....(let's call it a draw) if we can't progress...why wouldn't we "regress"?
interesting stuff....
| Loadus |
| Posted: Jul 31 2004, 05:53 PM |
I've used TooLame to encode Layer II audio to AVI stream many times ...
It works more than fine and the audio quality of TooLame's engine is very good. The problems start, when I use the experimental VBR encoding on the stream.
More to come, after I get some time to do more tests - Layer II VBR to MPEG-1 stream? Hmmmm....
| Posted: Aug 1 2004, 03:17 AM |
It's been a while since I read the spec, but I seem to remember that VBR encoding wasn't allowed for Layers I and II, only Layer III. (Someone correct me if I'm wrong...)
Of course that doesn't mean it can't be done, just that it might be out of spec. In any case, MPEG streams fully support Layer III VBR audio and there shouldn't be any problems on a PC. But I have serious doubts whether it will work on other hardware devices, like a DVD player.
| stephanV |
| Posted: Aug 1 2004, 10:12 AM |
Well, I believe the bitrate is defined in each MPEG1 audio frame header no matter which layer you use, so in principle it should be possible. Although, IIRC I read somewhere that layer I and II decoders did not necessarily have to decode VBR for whatever reason. A layer III decoder should always be able to decode VBR. I'll try to look it up.
| stephanV |
| Posted: Aug 1 2004, 01:38 PM |
then again, from toolame site
| QUOTE | VBR mode works by selecting a different bitrate for each frame. Frames which are harder to encode will be allocated more bits i.e. a higher bitrate.
LayerII VBR is a complete hack - the ISO standard actually says that decoders are not required to support it. As a hack, its implementation is a pain to try and understand. If you're mega-keen to get full range VBR working, either (a) send me money (B ) grab the ISO standard and a C compiler and email me. |
its a bit weird specified then though, making it possible but not being required to support it... (and what does the word hack mean anyway )
AFAICT from that document VBR mpeg layer II is only possible for limited bit rate ranges (depending on sampling frequencies; it can only make use of one bit allocation table)
| Loadus |
| Posted: Aug 2 2004, 01:11 PM |
Yup. VBR for Layer II works on PC, but hardware players say no-no when you try to play it...
I just love these insane specifications.
