My Browser Is Denying Certain Things From Here.
rjisinspired
Posted: Jul 30 2010, 02:24 PM
My avatar and some web actions? I'm getting an alert from something called "ABE" in Noscript. I never blacklisted nor denied Vdub from web actions so I don't understand what this is about?
Has anyone else been having problems with Noscript?
I can't view my avatar because ABE is blocking it like it's malicious or something and I've never set Noscript to block Vdub site.
rjisinspired
Posted: Jul 30 2010, 02:27 PM
Here is the message by ABE:
http://rjschat.dyndns.org:8080/Paranoha/AP...DUB/ABE-msg.jpg
Hmm looks like all of my images are being deflected?
Posted: Jul 30 2010, 03:27 PM
You're getting hit by ABE because it's blocking external sites from using internal resources
This is normally a good thing (but not so much for you in this case)
Have a look at point 8.11
http://noscript.net/abe/
There's also a section on configuring abe here
http://arstechnica.com/business/guides/201...of-tracking.ars
rjisinspired
Posted: Jul 31 2010, 03:00 PM
Something must be wrong with Noscript. I allowed Vdub a long time ago but it wasn't on the whitelist when I just checked.
I went to add this site to the whitelist and the allow button is greyed out.
I started getting this problem when I got the last update of Noscript
Posted: Jul 31 2010, 03:45 PM
It's your site that's blocked from the internet
That first link should have been http://noscript.net/faq
Section 8.11 and thereabout
Abe's there to stop cross-site scripting
http://en.wikipedia.org/wiki/CSRF
you want a rule like
Q:   ABE seems to block Facebook's Photo Uploader Plugin. What can I do?
A:   Open NoScript Options|Advanced|ABE, select the SYSTEM ruleset, and insert the following rule in the beginning of the text box:
# Facebook Photo Uploader Plugin exception
Site http://127.0.0.1:*/photos/uploader_iframe.php?*
Accept from *.facebook.com
You also need to add 127.0.0.1 to your NoScript Options|Whitelist.
So yours might be
Accept from *.virtualdub.org
But as you're running a webserver on your own pc then you might just consider turning off abe in the noscript options
That or add rules for each site that you'll get this problem on
rjisinspired
Posted: Jul 31 2010, 04:16 PM
I think I'll turn off ABE. My site is as old as cheese and doesn't even contain any JS nor anything that should trigger ABE. It's all html and css, nothing else.
I could just put my dns name in there but I'll just disable ABE.
Thanks for explaining that it is blocking me.
5 replies since Jul 30 2010, 02:24 PM Track this topic | Email this topic | Print this topic
<< Back to Off-Topic
