| rjisinspired |
| Posted: May 14 2010, 09:33 PM |
I have followed these instructions from videohelp to the tee
http://forum.videohelp.com/threads/221665-...286#post1284286
The logo disappears after sampling the second still frame, right after the analysis image is produced with the red, but after I go through the next steps then load the video, the logo is still there?
I'm confused to as what happened? |
| rjisinspired |
| Posted: May 14 2010, 09:37 PM |
ugh. I feel like an arse. Note to self: Make sure to remove the levels filter which was part of the saved settings (vcf file) if it had already been used. I had used the vcf save file for not only filters but for save settings and I didn't remove the levels filter when reloading the video. |
| rjisinspired |
| Posted: May 16 2010, 04:05 AM |
Funny thing I just noticed with using "fine red" as a mask is that I have two image samples of the same red value but only one works with the image I'm trying to fix. 255,0,0. Is this strange or what?
I hope the next logo I try to remove I don't get the "must have one red pixel" error when using the same value red. |
