Problems With Rfta?, I can't make a vcd of this file
Blootak
Posted: Nov 15 2002, 01:23 PM
mellow.gif I have a file with the name "Divx RFTA". When i tried to cut it with Virtualdub i got the "improper vbr audio" fault so following the instructions on the forum used Nandub. Now i have it in 2 parts but when i try to convert and burn using Nero i get an unspecified fault and cant continue. Does anyone know what i should do,or is my problem with the Rfta file? Thanks
Morsa
Posted: Nov 15 2002, 05:02 PM
I guess that you can´t make a VCD with VBR audio, thtá for sure.
jcsston
Posted: Nov 15 2002, 08:39 PM
Matroska Dev
You need to convert the audio to a format Nero can handle.
Open the file in NanDub and set the video to direct stream and the audio to Full Processing. Under the Audio Commpression I would choose PCM (Uncommpressed) because Nero will recompress the audio when converting to MPEG. Save the file to another AVI file and use that file in Nero.
Use the Matroska file format
2 replies since Nov 15 2002, 01:23 PM Track this topic | Email this topic | Print this topic
<< Back to General Discussion
