Splitting Avi S, Purple tint on alternating keyframes
unreal23
  Posted: Nov 13 2002, 10:55 PM
Hopefully someone can help me out on this. Every time I edit an avi file, and view the new file, there is a sort of purplish tint that flashes in and out every few keyframes. Similar to when you have speakers too close to the tv, and a purplish stain appears on the screen. But in my case, the video alternates between normal color and that puplish tint. Any suggestions? Thanx
Neo Neko
Posted: Nov 13 2002, 11:03 PM
VirtualdubMod Alpha tester
Unfortunatly I am not aware of a way to fix it. But I have known it to happen only with MSMPEG4 encoded content. Is that the case here?
unreal23
  Posted: Nov 13 2002, 11:13 PM
I really am not sure the format of the avi's. They all are dvd rips, and I have tried 10 to 15 different files with exactly that same problem. Another thing, I can see that puplish tint even when I'm in the process of marking the section of the file to be cut. So the problem is there when before virtual dub begins to cut the file
Morsa
Posted: Nov 13 2002, 11:46 PM
What codec are you using?
unreal23
Posted: Nov 14 2002, 12:03 AM
divx 5.02
Morsa
Posted: Nov 14 2002, 12:05 AM
Are you using any filter, something else?
May be the file is Xvid?
When you play it in Media player is it purple too?
If the case is yes, did you try using ffdshow?
unreal23
Posted: Nov 14 2002, 12:13 AM
No not using any filters and dont think any of the files Ive tried are xvid. Ive tried opening with divx, powerdivx and media player, all with same results. What's ffshadow?
Morsa
Posted: Nov 14 2002, 12:16 AM
ffdshow is a directshow filter that works really good, download it and try it.
Tell me what happens.
Did you check Vdub, is it all wright?
unreal23
Posted: Nov 14 2002, 01:13 AM
It's set to direct stream copy, I can't use any filters. Unless I'm not understanding it properly? I did download and install ffshadow tho
Morsa
Posted: Nov 14 2002, 01:19 AM
So what happened?
unreal23
Posted: Nov 14 2002, 01:42 AM
I can't use filters in direct stream mode
Morsa
Posted: Nov 14 2002, 02:03 AM
I know, but what happened with ffdshow?
Did your file play correctly via ffdshow?
I mean using Windows media player.
11 replies since Nov 13 2002, 10:55 PM Track this topic | Email this topic | Print this topic
<< Back to General Discussion
