| Morsa |
| Posted: Nov 2 2002, 09:44 PM |
Well finally here it is, the only one project with all VD modifications together.
http://sourceforge.net/projects/virtualdubmod |
| Sarreq Teryx |
| Posted: Nov 3 2002, 05:42 AM |
VirtualdubMod Alpha tester
based on 1.4.10 or .11?
| Sarreq Teryx |
| Posted: Nov 3 2002, 05:50 AM |
and also, the package on sourceforge is just DLLs, do we just plop them into the existing VD folder?
| Suiryc |
| Posted: Nov 3 2002, 07:46 PM |
Developer of VirtualdubMod
Group: VirtualdubMod Team
Hi
it is based on VirtualDub 1.4.10 The dlls are the only things available at the present time (a release of the exe should appear soon).
| Morsa |
| Posted: Nov 3 2002, 08:44 PM |
when 1.4.11 will arrive?? Asking about Virtualdubmod based upon version 1.4.11.
| Kippesoep |
| Posted: Nov 3 2002, 09:53 PM |
It just did, a few days ago. |
| Suiryc |
| Posted: Nov 4 2002, 10:46 PM |
VirtualDubMod 0.1a is released.
As many may know, this is a sourceforge project created by the developers of VirtualDubAVS, VirtualDubMPeg2 and VirtualDubOGM to merge them all.
We all hope everything went all right
Please post all bugs / requests on our project page. This eases up things for us a lot.
P.S: It's still based on 1.4.10, but we're working at it.
| Suiryc |
| Posted: Nov 10 2002, 06:25 PM |
VirtualDubMod 1.4.11.1 is out :
[VirtualDubMod 1.4.11.1] Cyrius: - Enabled VirtualDubMod.vdi (debug information file) generation in project settings. Need MapConv.exe (sources provided by Avery Lee on VirtualDub's web site) and ia32.vdi (provided by Avery Lee in the original 1.4.11 sources) to be in the sources directory when compiling. You can use the .exe zipped in MapConv.zip (in the CVS). - Streams in the input OGM file can now be demuxed. To demux a stream, select it in the "OGM inputs" window. (see "OGM -> Show inputs"). Demuxing is made this way (without WAV header, except in last case) : * Ogg Vorbis -> Ogg file * AC3 stream -> AC3 file * MP3 stream -> MP3 file * SRT stream -> SRT file (non-DOS format) * other audio streams (of other type) should be demuxed with a WAV header as if using "Save WAV" (but I can't tell this works because I don't have no-Ogg/AC3/MP3/SRT streams in my test files ) As when using "Save WAV", subsets have an effect on demuxed files (but don't use it as a precise cutter , because it is not intended to be one). - VBR MP3 files not being accepted bug fixed. However the resulting AVI can't be properly re-edited with VirtualDubMod (due to VirtualDub VBR correction routines). Moreover as a lot of person already said it, I recommand you to use only CBR streams within AVI files
Pulco-Citron: - Merged with VirtualDub 1.4.11 (lots of features untested). - Fixed YV12 handling (sh0dan's code). - Audio : * Disabled Audio/Ogg Vorbis Audio menu item. Until someone fixes the code, if it is possible. * Cosmetic fixes in Audio menu (when you select WAV audio for instance, it remains selected). * Minor (as far as I know) bug fixes in dual audio handling.
Belgabor: - Made the AVS Editor a general script editor. * Can open any file now. Auto-opens the opened movie if its an avs file. * Gave it a nice icon  * Status shows caret position * Some more useful Script editor <-> main window interaction - Updated the app icon to that from 1.4.11 and changed it a bit to make it distinguishable from the unmodified VirtualDub - Some minor fixes
| ChristianHJW |
| Posted: Nov 12 2002, 02:59 PM |
Great !
Suiryc, dont forget to add me to your dev list on sf.net/projects/virtualdubmod ... as 'helping hand' , or whatever .
| Suiryc |
| Posted: Nov 12 2002, 03:18 PM |
@ChristianHJW pulco-citron should be back tomorrow
(hope he has nothing against you )
| Melkor |
| Posted: Nov 14 2002, 10:13 AM |
What about NanDub? |
| Suiryc |
| Posted: Nov 14 2002, 01:47 PM |
@ChristianHJW You have been added
@Melkor What do you mean ? VirtualDubMod merges 3 projects : - VirtualDubAVS by belgabor : add some usefull tools related to AVISynth (script generation / handling, ...), plus some patch floating around on the net (VCR patch I think ... I don't remember everything ) - VirtualDubMpg2 by pulco-citron : add Mpeg2 (VOB / thanks to DVD2AVI) support (now with YV12 input), and use Nandub audio features (i.e. AC3/MP3 input - not Ogg anymore - and secondary audio track) - VirtualDubOGM by me : add OGM and PNG support (as input and output)
| ChristianHJW |
| Posted: Nov 14 2002, 10:18 PM |
Thanks Suiryc !!
I created another ML ( -general ) , in addition to the -devel list. There are always things to be discussed that dont belong onto technical -devel list .
I also commited both lists to gmane.org, so everybody with a newsreader should be able to participate without subscribing, via news://news.gmane.org , gmane.comp.video.vdubmod.devel and .general .
Mail to the -devel list is out, i'd like to repeat the goals we have with the project ( important to make this clear to ourselves ).
Thanks again for letting me into the project
