M2ts Blue Ray Video
3nabiae
Posted: Jan 13 2015, 05:22 PM
do you know the way how split or cut m2ts blue ray video without loss quality of video
which the best program for that also why m2ts not open on virtual dub
JaliM
Posted: Jan 13 2015, 05:52 PM
QUOTE (3nabiae @ Jan 13 2015, 05:22 PM)
A little buggy but freeware,
http://www.videohelp.com/tools/H264TS-Cutter
or (also freeware)
http://www.videohelp.com/tools/TSSniper
You can look at Avidemux and tsMuxeR
One of the best but $40:
http://www.videohelp.com/tools/Smart-Cutter-Ps-Ts
3nabiae
Posted: Jan 13 2015, 09:09 PM
i want know why not virtualdub open m2ts
why only ts i hope in future try to add plugn m2ts
3nabiae
Posted: Jan 14 2015, 04:14 PM
QUOTE (3nabiae @ Jan 13 2015, 09:09 PM)
Posted: Jan 14 2015, 07:21 PM
I have no example of an m2ts-file, but I suppose it must be possible to open it with VirtualDub, after you have downloaded and have installed the FFMpeg input plugin for VirtualDub.
You can find and download it from here (thanks to dloneranger for his recent updates to it):
> http://sourceforge.net/projects/virtualdub...peginputplugin/
Installing the plugin, means unzip the content of the correct pluginsXX-bit folder to the pluginsXX subfolder of your VirtualDub installation.
After that, start VirtualDub, click the File-menu > Open video file..., and in the dialogbox, do one click onto the *.m2ts file, at "Files of type" do select "FFMpeg Supported Files", and then click Open.
JaliM
Posted: Jan 15 2015, 07:31 AM
Yes. While it is possible to open m2ts files with this plugin, it's not possible to do a Direct Video Stream Copy, so this process is lossy (I mean not lossless)
5 replies since Jan 13 2015, 05:22 PM Track this topic | Email this topic | Print this topic
<< Back to General Discussion
