| Greme |
| Posted: Jul 16 2014, 05:45 PM |
Hi, apologies with what is probably a stupid query, but I am having problem with using the /i invoke command to pass parameters to virtual dub.
I am currently attempting to batch-segment a set of avi files. To do so, I have created the following batch file
| CODE | @echo off set vdub="D:\Vdub\vdub.exe" set myscript="D:\Vdub\scripts\autosplitterscript.vdscript" set framecut=125 set /a COUNTER=0 set /a ERRCNT=0
:loop if "%~f1".=="". goto theend mkdir "%~p1"\split\%~n1 %vdub% /i %myscript% "%~f1" "%~p1\split\%~n1\%~n1%~x1" %framecut% /x if errorlevel 1 ( set /a ERRCNT=%ERRCNT%+1 echo Error....&pause ) set /a COUNTER=%COUNTER%+1 shift goto loop
:theend set /a SUCCEED=%COUNTER%-%ERRCNT% echo. echo All (%COUNTER%) files processed echo %SUCCEED% files processed sucessfully, %ERRCNT% files produced errors pause |
and the following vdscript file
| CODE | VirtualDub.Open(VirtualDub.params[0],"",0); VirtualDub.audio.SetSource(1); VirtualDub.audio.SetMode(0); VirtualDub.audio.SetInterleave(1,500,1,0,0); VirtualDub.audio.SetClipMode(1,1); VirtualDub.audio.SetEditMode(1); VirtualDub.audio.SetConversion(0,0,0,0,0); VirtualDub.audio.SetVolume(); VirtualDub.audio.SetCompression(); VirtualDub.audio.EnableFilterGraph(0); VirtualDub.video.SetInputFormat(0); VirtualDub.video.SetOutputFormat(0); VirtualDub.video.SetMode(0); VirtualDub.video.SetSmartRendering(0); VirtualDub.video.SetPreserveEmptyFrames(0); VirtualDub.video.SetFrameRate2(0,0,1); VirtualDub.video.SetIVTC(0, 0, 0, 0); VirtualDub.video.SetCompression(); VirtualDub.video.filters.Clear(); VirtualDub.audio.filters.Clear(); VirtualDub.project.ClearTextInfo(); VirtualDub.SaveSegmentedAVI(VirtualDub.params[1], 2048, VirtualDub.params[2], 3); VirtualDub.Close(); |
However, I get the error message "Error during script execution at line 1, column 81: Overloaded method SaveSegmentedAVI(string,int,string,int) not found. If I change "VirtualDub.params[2]" to 125 in the vdscript file then the process completes without error.
The reason I'm passing through 125 instead of using the value straight in the script is that eventually I want to enable the user to enter this value themselves - i'm just testing passing down the parameter.
I realise that there is probably a very obvious mistake or error that I'm making, but I can't for the life of me work it out!
Any help would be appreciated.
Greme |
| raffriff42 |
| Posted: Jul 16 2014, 08:05 PM |
I think you want this: VirtualDub.SaveSegmentedAVI(VirtualDub.params[1], 2048, Atoi(VirtualDub.params[2]), 3); (Atoi() converts a string to an integer)
But it looks like you would still have too many arguments to SaveSegmentedAVI, per the documentation void SaveSegmentedAVI(string filename, int spacethresh, int framethresh); |
| Posted: Jul 16 2014, 08:10 PM |
The fourth param is a newer addition than in the docs It's the minimum number of digits for filename
| Greme |
| Posted: Jul 17 2014, 08:29 AM |
That's brilliant, I forgot that the parameter would be passed as a string.
Just in case anyone strangely has this problem in the future and arrives here, the line that worked for me is: VirtualDub.SaveSegmentedAVI(VirtualDub.params[1], 2048, Sylia.Atoi(VirtualDub.params[2]), 3);
Thank you both very much for your help with this! |
