Batch External Encoder?
suomynonanum2
Posted: Jun 27 2014, 04:51 PM
just wondering if there's a way to convert an entire folder of vids usung an external encoder without adding each job one by one to job control. i know you can do it without an external encoder, but if i want it to be mp4, i have to use external encoder. thanks.
raffriff42
Posted: Jun 27 2014, 06:05 PM
Not as far as I know. The best I can suggest is: set a custom keyboard shortcut for "Jobs.ExportViaEncoder" (I use Control+Shift+E) to (slightly) speed up the process of adding files.
If you don't like that idea, I'd suggest you try a different tool. WinFF is a good one. Select a preset, drag in a bunch of files, go.
suomynonanum2
Posted: Jun 28 2014, 07:06 AM
i could also just use handbrake to mass covert, but i'm also trying to take advantage of the filters available to virtualdub :-/.
Posted: Jun 28 2014, 08:06 AM
You can do it with a .bat file and a virtualdub script (you can copy one from virtualdub's .jobs file)
There's an example of doing a direct stream copy at http://forums.virtualdub.org/index.php?act...hl=&#entry96803
Also, if you use a shared jobs list, you can have one virtualdub working on a queue while adding too it with another virtualdub (or .bat file)
Help for that's on here somewhere and in virtualdub's help file
raffriff42
Posted: Jun 28 2014, 01:21 PM
You're right ohmy.gif plus I forgot about my own script generating batch file, posted under
Using vdub.exe as a Muxer.
Here's yet another one (it's the oldest, and also seems more polished):
Scripted VirtualDub Job Creation
suomynonanum2
Posted: Jun 30 2014, 05:50 AM
ah, i didn't even think to inspect the job control file! i didn't realize it was just plain text :-p. thanks for the info! i just took a cursory glance at the resources you provided, but it looks promising. hopefully i'll be able to create a script that can automatically produce the jobs that i need!
5 replies since Jun 27 2014, 04:51 PM Track this topic | Email this topic | Print this topic
<< Back to General Discussion
