How Do I Remove All Delta/drop Frames From An Avi?
Soulvomit
  Posted: Apr 18 2014, 11:27 PM
Is there a way of stripping an AVI of all its delta frames without transcoding (Direct Stream Copy)? The one I'm working on at the moment has a true variable frame rate of about 25.543~ padded with drop frames to 1,000. I've tried "Convert to fps" but it isn't perfect as the rate isn't constant and so I'm still left with a few delta frames in the resulting AVI because the frame decimation isn't accurate. I have the timecodes so synchronization won't be an issue afterwards.
Thank you.
Posted: Apr 19 2014, 07:05 AM
There's unticking 'preserve empty frames' option on the video menu, but that doesn't work in direct stream copy mode....
You might be able to do it with ffmpeg and it's -vsync options? (if not recompressing is a requirement)
1 replies since Apr 18 2014, 11:27 PM Track this topic | Email this topic | Print this topic
<< Back to General Discussion
