| gisnar |
| Posted: Feb 7 2014, 08:04 PM |
I'm trying to enable opening of .mov files in VirtualDub. I have tried both the "Quictime Plugin" and the "FFMpeg Input Plugin". The first one of these has a readme file that specifies the unzipped plugin files to be placed in a plugin folder (for 32 bit or 64 bit version) in VirtualDub's program folder. I have done this, but when I try to open a .mov file I get a message in the middle of the of each VirtualDub window (small font) that says "Missing Codec" and another word I cannot read. This happens for both the Quicktime and FFMpeg plugins.
Any suggestions for what the missing codec is or what else might be wrong would be greatly appreciated!
Thanks, Gisnar |
| Posted: Feb 7 2014, 08:50 PM |
FFMPeg plugin doesn't give that message so I suspect you aren't actually using the plugins
To use the plugins On the file menu, select open video file Click on the video file you want to load so it is selected Change the 'files of type' to the plugin you want to use Now click OK
FFMpeg should load it ok as it doesn't require codecs Quicktime plugin requires the correct codecs on your pc - the file information dialog shows what codecs it uses
| gisnar |
| Posted: Feb 14 2014, 02:43 AM |
Hello dloneranger,
Thanks very much for your insights and sorry for the late reply. I will have to review what I did again and hopefully it will work. Appreciated your help! |
