| parametric |
| Posted: Dec 22 2013, 12:14 AM |
Having digitised from VHS using a DVD recorder, in the HQ mode, the resultant material when viewed constantly "jumps" from what you might consider "correct" colour - to a washed-out level.
Its as if the "saturation" or "colour" levels are being randomly tweaked.
The effect is not smooth, but looks like a switching between two "values".
I'm GUESSING that this is due to dropouts/wear/age of the original tape.
Can VD possibly take the "correct" colour info and write it to the washed-out sections and thus create a uniform colour response throughout?
Best Regards
parametric |
| Posted: Dec 22 2013, 12:22 AM |
There are some VHS filters for that kind of thing http://neuron2.net/flaxen/flaxen.html
There's another one by jpsdr on this site as well, but I can't find it right now
There's a fairly long list of filters here http://www.infognition.com/VirtualDubFilters/ http://neuron2.net/mine.html http://neuron2.net/hosted.html http://neuron2.net/other.html
| parametric |
| Posted: Dec 22 2013, 12:28 AM |
Thanks for your quick reply, dloneranger - I'll take a look.
Best Regards
parametric |
