Input And Output Video Pane Is Motionles, Settings
UncleSasha
Posted: Aug 19 2013, 06:22 AM
VirtualDub 1.10.3 (build 35390)
OS Windows XP SP3.
During coding the image remains fixed in window Input and Output.
How to adjust Virtual Dub, that during coding
The image was mobile?
At usage VirtualDub 1.9.11 (build 32842) the image was mobile
Posted: Aug 19 2013, 06:38 PM
In VirtualDub's View-menu, the Input video pane and the Output video pane should be checked
(checkmarks should be visible at the left of these menu entries).
UncleSasha
Posted: Aug 19 2013, 08:23 PM
Input video pane and the Output video pane is checked.
The image is, but it is fixed as a photo.
Posted: Aug 19 2013, 08:56 PM
Please check with the latest experimental build:
> http://www.virtualdub.org/beta/VirtualDub-...10.4-test11.zip
Maybe it was a bug in the version that you are actually using/testing.
See fixes:
> http://forums.virtualdub.org/index.php?act...ST&f=15&t=21216
> http://forums.virtualdub.org/index.php?act...ST&f=15&t=21459
UncleSasha
Posted: Aug 21 2013, 12:02 PM
Has checked up VirtualDub 1.10.4 (build 35475)
Any changes.
Input and Outpur windows is still.
Posted: Aug 21 2013, 07:52 PM
The only way I can reproduce this phenomenon is to set Video-menu to:
- Direct stream copy OR
- Fast recompress OR
- Normal recompress
When Video-menu is set to:
- Full processing mode
then the Input pane as well as the Output pane do show the progress of the processing
(one refresh at every 100 to 300 images in VirtualDub 10.4.xx - - in VirtualDub 1.9.11 the refresh is more frequently)
If this is NOT the reason, you can eventually try to remove all settings from VirtualDub in the Windows Registry.
The key is HKEY_CURRENT_USER\Software\VirtualDub.org
First make a File > Export of this key and then delete it
(always take care when you are executing these kind of things)
Restart VirtualDub after removing the key and see what it gives
UncleSasha
  Posted: Aug 22 2013, 06:12 PM
Abrazo, many thanks for the help.
All has earned, as before, after removing the key.
6 replies since Aug 19 2013, 06:22 AM Track this topic | Email this topic | Print this topic
<< Back to General Discussion
