Mp4 Plugin For Virtualdub
jcool
Posted: Apr 9 2013, 07:24 PM
Is there a plugin for mp4 files in virtualdub because I want switch the bad audio with better audio or is there a program for that without recompression?
Posted: Apr 9 2013, 08:06 PM
There is indeed, http://forums.virtualdub.org/index.php?act...=ST&f=7&t=19488
The fccHandler Quicktime plugin is better though iirc
For just taking the audio out and adding a new one, you could use mp4box
A GUI version can be found at http://my-mp4box-gui.zymichost.com/index.html
You want to "demux" the tracks and then "mux" the video and the new audio
evropej
Posted: Apr 9 2013, 11:54 PM
Use the virtualdub file I gave you, it has it in there. When you open files, make sure you select from the drop down mov mp4.
Make sure you install quicktime from apple.
flashmanblack
Posted: May 14 2013, 02:10 AM
QUOTE (dloneranger @ Apr 9 2013, 08:06 PM)
but is does not work for me and i have tried it many times
-vdub-
Posted: May 14 2013, 03:37 AM
If cannot do with virtualdub use a tool to demultiplex then later multiplex to a new video mp4. Where you use your replacement audio stream instead of the original audio stream. See here for tools http://www.videohelp.com/tools/sections/vi...de-multiplexers
Having a gui mp4 video-de-multiplexer tool would make it easier for you to do this
evropej
Posted: May 17 2013, 08:15 PM
You can try this for encoding only
http://www.evropej.com/freemake.mp4
5 replies since Apr 9 2013, 07:24 PM Track this topic | Email this topic | Print this topic
<< Back to General Discussion
