Nelp Help With Video
jcool
Posted: Apr 4 2013, 02:05 PM
Hello to all! I have a 352x480 mpeg2 video which is 2hrs long but I want to clean it up because the quality is not good. What are the steps to fix this and is is best to resize it. I'm kind of a newbie with this so please help me
Posted: Apr 4 2013, 03:43 PM
It'll all depend on what you mean by poor quality
A better description of what's wrong with it would be useful
There are filters that can smooth out, sharpen, change the contrast/brightness/saturation, clean up vhs noise etc etc etc
Without knowing what you're trying to fix, it's a 'how long is a piece of string' question
Resizing. It'd be better to see for yourself
Sometimes smoothing out textures works better if it's resized, sometimes it's worse
It's best to just have a play with all the things before doing the final version, so you can get comfortable with what you're doing
As well as the built in filters, there are a lot of ones you can download and use
They usually come in .zip files, extract the .vcf file and move that into a folder called 'plugins32' inside virtualdubs folder
(if it's not there, just make a new folder with that name)
Some useful filters are:
2d cleaner http://neuron2.net/2dcleaner.html
MSU smart deblocking http://www.compression.ru/video/deblocking...locking_en.html
MultiAdjust https://sourceforge.net/projects/multiadjust/
MSharpen http://neuron2.net/msharpen/msharpen-vdub.html
jcool
Posted: Apr 4 2013, 04:05 PM
I'm a newbie at this if I send a screenshot and the parameters to you could you give your opinion about it? I would greatly appreciate it
Posted: Apr 4 2013, 04:25 PM
Yup, a few average screenshots would help see what's wrong
jcool
Posted: Apr 4 2013, 05:00 PM
How do you attach files to a post because I don't see where its at?
Posted: Apr 4 2013, 05:03 PM
You can't, but you can upload them to somewhere else (like imageshack or pixhost) and put the links here
jcool
Posted: Apr 4 2013, 05:11 PM
Ok here are the links:
http://imageshack.us/photo/my-images/96/nve00006b.png/
http://imageshack.us/photo/my-images/600/nve00005.png/
http://imageshack.us/photo/my-images/841/nve00004.png/
http://imageshack.us/photo/my-images/828/n.../nve00003o.png/
http://imageshack.us/photo/my-images/52/nve00002r.png/
Here is video info:
Complete name : C:\Users\WJL\Documents\NeroVision\ImportedVideo\4-2-2013 70445 PM.0001\0001.mpg
Format : MPEG-PS
File size : 1.99 GiB
Duration : 2h 0mn
Overall bit rate : 2 368 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=15
Duration : 2h 0mn
Bit rate mode : Variable
Bit rate : 2 064 Kbps
Nominal bit rate : 3 758 Kbps
Width : 352 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.408
Stream size : 1.73 GiB (87%)
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Muxing mode : DVD-Video
Duration : 2h 0mn
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Delay relative to video : -67ms
Stream size : 220 MiB (11%)
Text
ID : 224 (0xE0)-DVD-2
Format : EIA-608
Muxing mode, more info : Muxed in Video #1
Stream size : 0.00 Byte (0%)
Posted: Apr 4 2013, 07:16 PM
Probably something like resizing larger, sharpen the edges and little bit of smoothing would help
Here's just what altering the contrast/brightness looks like (with a bit of extra saturation)
In the image, the left half is altered and the right half is the origional
jcool
Posted: Apr 4 2013, 09:40 PM
What would be a good resize option and have you tried the sharpen and smoothing
Posted: Apr 5 2013, 05:06 AM
They're things you'd have to play with to see what looks best
To be honest, there are so many filters to test on it, I don't have time
The resizer has an option to keep the aspect ratio the same, so you can play with sizes there
If you click the aspect ratio->'same as source' you can type in a new height and the width will be calculated for you
Make sure you also click the Codec-friendly sizing->'Multiples of 4' so that codecs will accept the new width/height ok
jcool
Posted: Apr 5 2013, 12:32 PM
I'm trying the resize option with resolution of 480x360 2d cleaner, deinterlace, hsv adjust with saturation of 165%, mssharpen and deblocking
evropej
Posted: Apr 6 2013, 03:38 AM
can you post a link to the video?
i will make a video tutorial for you on how to fix these type of videos.
here you go, try this out, i included all the filters too
www.evropej.com/video.zip
jcool
Posted: Apr 6 2013, 02:22 PM
evropej here are the sample links:
http://www.mediafire.com/?ghrvx3z3c1hanm7
http://www.mediafire.com/?ccp6fac2d7fp998
evropej
Posted: Apr 6 2013, 07:56 PM
Here are some results of deinterlacing, upscaling to 720p, denoising, deblocking, and sharpening. I used neat video for denoising which is much better than msu but used the same process as I outlined in the video I posted.
www.evropej.com/movies.zip
jcool
Posted: Apr 6 2013, 10:15 PM
Ok I'll check it out thanks so much for your help! Did you look at the links I posted and if so what would be a good setting that I could use to fit the mpeg on dvd because it takes 15 hours to process it in virtualdub
28 replies since Apr 4 2013, 02:05 PM Track this topic | Email this topic | Print this topic
Pages: (2) [1] 2
<< Back to General Discussion
