| gorse |
| Posted: Sep 15 2002, 03:17 PM |
I am trying for the first time to create Video CD.
I have completed the Divx Codec tab, and have got as far as "setting up the audio codec and encoding" and preparing "Job Control List" but have got stuck. The instructions in the Magazine say "check" the "Defer Processing Box" Where or how do I find this.
Thanks in anticipation Gorse |
| drizztcanrender |
| Posted: Sep 15 2002, 08:35 PM |
When you save the avi(after you put in the options ) look in the lowest part of the window.It says deffer processing.Do it for both passes and then go to file->job control and press start on the first one. |
