| jim a |
| Posted: Sep 13 2002, 01:59 AM |
i tired the delaying the audio like in my first post titled first time user please help. i have it matched in the gbegining but it gets worse as the movie goes on now what do i do |
| Ciler |
Posted: Sep 13 2002, 06:29 AM |
This is quite difficult to deal with...
Here are several things you can try :
- Go to menu Video > Frame-Rate > "change so that video and audio duration match". You might have to re-process the delaying to have things in-synch. - Maybe your framerate is not set correctly, like 24.010 whereas it should be 24.000, change it in the same menu as above
Anyway, on the audio conversion process, did you make a 48.000 -> 44.100 Hz conversion ?
(last thing, there's no use to make a new topic at every question, and please try to choose more efficient titles, like "audio synch problem". This makes search engine more efficient) |
| jim a |
| Posted: Sep 13 2002, 10:55 AM |
that last part about making a 489 to 41 conversion what do you mean hehe sorry |
| jim a |
| Posted: Sep 15 2002, 12:19 PM |
what did u mean about the audion conversion somethinglike 48 to 44 i dont know exactly what u mean |
| Ciler |
| Posted: Sep 17 2002, 06:19 AM |
When creating your movie, which software and which setting did you use to process the audio ? |
