Please Help With First Time User
jim a
Posted: Sep 11 2002, 11:44 PM
i split my first avi with virtualdub and follwed a step by step prossces that i found on the web. i thought this is easy and everything went great until i viewed what i split and the sound is off mouths move and the speak later u know what im talking aobut like a old kong fu movie can any one help me out. wink.gif
jim a
Posted: Sep 12 2002, 10:54 AM
why does everyone read but no help so far?
ProfDrMorph
Posted: Sep 12 2002, 12:12 PM
if the a/v desync is constant ( the amount of time between lip movement and real speech ) you can try opening the AVI file in VDub again, set Video and Audio to Direct Stream Copy and then goto Audio | Interleaving | Audio Skew Correction. You can delay the audio track this way ( with negative numbers you can make it play earlier ) and thus fix the desync.
jim a
Posted: Sep 12 2002, 10:25 PM
sounds like alot of trial and error but worth it thanks for the help
3 replies since Sep 11 2002, 11:44 PM Track this topic | Email this topic | Print this topic
<< Back to General Discussion
