| jcsston |
| Posted: Dec 10 2002, 06:16 PM |
Matroska Dev
Are there are differences between the YUV2 to RGB32 conversion process in AviSynth and VDub?
| Posted: Dec 10 2002, 07:08 PM |
Probably not. Since both Avisynth and Huffyuv are partly based on VirtualDub, most likely the conversion code is the same.
| Posted: Dec 10 2002, 11:24 PM |
Actually, yes, there is a difference -- Avisynth's color conversion code is based on Huffyuv's, not VirtualDub's. Avisynth assumes coaligned chroma samples, whereas VirtualDub decodes chroma in-between (half-pixel off). For consistency, when you need to process Avisynth output with VirtualDub you should have Avisynth do the conversion. |
| jcsston |
| Posted: Dec 10 2002, 11:52 PM |
Matroska Dev
thanks
| Posted: Dec 11 2002, 04:28 AM |
@phaeron: Thanks again!
After looking at the code, it's clear that Huffyuv has nothing of VirtualDub in it (that I can see). In fact, it looks like VirtualDub has two different conversions (one of them "hq"). Now I'm wondering which of the three conversions is fastest...
| Belgabor |
| Posted: Dec 12 2002, 07:06 PM |
Developer of VirtualdubMod
Group: VirtualdubMod Team
To give an update, afaik the color conversion routines come from XviD in the newest releases (not sure about 2.0.7, but i think the 2.5 alpha)
| sh0dan |
| Posted: Dec 19 2002, 10:17 AM |
Avisynth Developer
The XVID conversions in AviSynth 2.5 alpha are only used for YV12 planar conversions, since that is the only thing supported by XVID.
AviSynth still uses the same conversion routines for YUY2 as it always has. These conversions actually seems to have better precision than the XVID ones.
Since I don't know Virtual Dubs YUY2->RGB conversion, I think you should stick to Avery's recommendation. |
