| Chigaimasu |
| Posted: Oct 5 2004, 03:49 PM |
I am quite new to using VirtualDub and AviSynth, so I am just learning how to write a script properly. Right now, I am following this tutorial: http://www.animemusicvideos.org/guides/wor...ng_with_dvd.pdf
I have written the script as per the instructions of that tutorial, and saved is as a .avs file. According to this tutorial, I can open the .avs in VirtualDub. However, when I try to do so, I get this error:
| CODE | Avisynth open failure: LoadPlugin:"E:\Programs\AviSynth2\plugins\MPEG2Dec3.dll" is not an Avisynth 1.0 plugin (E:\dvd.avs, line 1)
I know that this is not a plugin for Avisynth 1.0, as I am using version 2.5. However, the tutorial writer seems to have no trouble with this, and he and I are using the same versions of both Avisynth and VirtualDub. All help for getting this to work is appreciated. |
| NuPogodi |
| Posted: Oct 6 2004, 11:47 AM |
i must confess that i stopped downloading this stupid tutorial after approx. 3 minutes of impatient waiting How hell large is it? and, what is more important, how about to copy-paste your avs-script and to give the other details by yourself ?
-------------------- Optimists believe that they live in the best of existing worlds. Pessimists are afraid of that's right... |
| Chigaimasu |
| Posted: Oct 6 2004, 02:56 PM |
I apologize. It didn't take me very long to download the tutorial, but this is the script that it gives you to write.
| CODE | LoadPlugin("E:\Programs\AviSynth2\plugins\MPEG2Dec3.dll") LoadPlugin("E:\Programs\AviSynth2\plugins\Decomb521.dll") MPEG2Source("E:\DVD rips\Cowboy Bebop\cowboy bebop dvd 1.d2v", idct=5, CPU=4, iPP=true) Telecide(order=0, guide=1, post=4) Decimate(quality=3)
It's very simple, and the error I get is in the first line. It's saying that MPEG2Dec3.dll is not an Avisynth 1 plugin. |
| NuPogodi |
| Posted: Oct 6 2004, 03:33 PM |
1. try to comment the 1st line - if i'm not mistaken MPEG2Dec3.dll is already the built-in function in the latest AviSynth... So, it might be just a conflict when loading external function with the same name. 2. on failure, goto WarpEnterprises filter collection and download filter... actually, there are several MPEG-filters. all must work for a proper AVS-version - either 2.0x or 2.5x 3. if none of MPEG-filters is working, download dgIndex by Donald Graft (advanced version of DVD2AVI), make d2v-project, then copy DGDecode.dll to the AviSynth's plugins folder and write in your script something like PP="E:\Programs\AviSynth2\plugins\" loadplugin(PP+"dgDecode.dll") MPEG2Source("Project.d2v",cpu=4,iPP=true) LoadPlugin(PP+"Decomb521.dll") # and so on Beleive me, it definitely works... i've tested zillion times!
| Wilbert |
| Posted: Oct 6 2004, 08:01 PM |
| QUOTE | | 1. try to comment the 1st line - if i'm not mistaken MPEG2Dec3.dll is already the built-in function in the latest AviSynth |
No, it's not build in.
| QUOTE | Avisynth open failure: LoadPlugin:"E:\Programs\AviSynth2\plugins\MPEG2Dec3.dll" is not an Avisynth 1.0 plugin (E:\dvd.avs, line 1) |
This means you are using AviSynth v2.0x. Get v2.5x. (If this is not the case it means you have a v2.0x floating around somewhere, perhaps in vdub folder. So search your hdd and remove all of them.) |
| NuPogodi |
| Posted: Oct 7 2004, 07:31 AM |
| QUOTE (Wilbert @ Oct 6 2004, 02:01 PM) | | QUOTE | | 1. try to comment the 1st line - if i'm not mistaken MPEG2Dec3.dll is already the built-in function in the latest AviSynth |
No, it's not build in. |
i thought that the remark "R.I.P." (Rest In Peace) in the WarpEnterprises collection says that the filter is already built-in. My mistake... Does it mean that the filter is no longer supported? hopefully, RIP is not related to the filter authors... otherwise, writing AVS-filters is more dangerous for their health then crossing the UK roads by citizens of other european countries.
| Wilbert |
| Posted: Oct 7 2004, 08:12 PM |
| QUOTE | | i thought that the remark "R.I.P." (Rest In Peace) in the WarpEnterprises collection says that the filter is already built-in. |
No. I means that the development of the filter is continued as the plugin which is listed next (of WarpE link):
decodefix100 (2003-10-12)
The most recent version can be found here:
http://neuron2.net/fixd2v/decodefix.html |
