Help! Problems With Avs Files!
DogFace88
  Posted: May 23 2003, 06:35 PM
Whenever I try to open an AVS file in VirtualDub, it says:
Avisynth open failure
AVIFileSource: couldn't open file
(C:\windows\desktop\tvshow.avs, line 2)
ChristianHJW
Posted: May 24 2003, 05:58 AM
Do you have latest AVISynth installed ? Its coming with Gordian Knot from www.doom9.org in the installer, or search on sourceforge.net for avisynth ( maybe http://sf.net/projects/avisynth ) ....
Belgabor
Posted: May 30 2003, 02:18 AM
Developer of VirtualdubMod
Group: VirtualdubMod Team
Could you post your script? Can't tell much without it.
[VirtualDubMod Homepage]
Please submit any bugs/patches/feature requests also using the respective tracker on our sourceforge page
IceBlack
Posted: Jun 2 2003, 01:50 AM
I am having a similar problem, but only in VirtualDub 1.5.4. I have tried it under 1.5.2 and it seems to work fine. The error I get is
AviSynth open failure:
Unrecognized Exception!
(C:\avsfile1.avs, line 1)
My script reads:
MPEG2Source("C:\decode1.d2v")
Telecide()
Decimate(5)
I get the same error if I use AviSynth 2.5 or older versions, and I have never had this problem before I tried using version 1.5.4. Any ideas?
Edit:
Ok, so I guess I do have the same problem in 1.5.2 also. It's wierd, if I open an .avs file right after I launch VDub, it works fine, but if I try to open it after I have already opened something else, I get that error. Could it be something with my AVISynth setup?
3 replies since May 23 2003, 06:35 PM Track this topic | Email this topic | Print this topic
