| SillKotscha |
| Posted: Jan 4 2003, 12:38 AM |
smart Moderator
hi folks,
some of you have heard about 'Deinterlace MAP' I guess . I use this VDUb_Filter for my tv_caps and in my case it works very well - it's just great!!
As you know GKnot now supports *avi for input and for segmented (captured) avis, it's like that...
| CODE | | SegmentedAviSource("D:\capture\capture000.avi") |
Note that SegmentedAviSource has a bug in AviSynth v2.07, as a work around you should manually delete the last (small, empty) segment or use v2.06.
thanks to hakko504 & Wilbert according to this thread here:
- http://forum.doom9.org/showthread.php?s=&t...&threadid=41085
or just use avisynth 2.5_a_03.01.03 (according to me )
as I said, I like 'Deinterlace MAP' very much and I contacted Shaun Faulds (author of this filter) and ask him, if he is willing to develop his filter to avisynth...
If you're interested, then you may want to read here:
link updated
support me, support me to push him a little bit - and we'll have another wonderfull avisynth_plugin
cheers Sill
| jcsston |
| Posted: Feb 1 2003, 10:07 PM |
Matroska Dev
I would like an AviSynth version of DeinterlaceMAP, I tried the FieldDeinterlace() in the Decomb package but the output was not as sharp as DeinterlaceMAP.
| SillKotscha |
| Posted: Feb 1 2003, 11:01 PM |
smart Moderator
yeah, vote for it
it's time to reawake Shaun Faulds
