Won't Capture Properly In Windows 2000
cosworth
Posted: Dec 5 2002, 06:17 PM
When I capture from my WinTV card with either the WDM or the Hauppauge drivers, the capture initiates but will not stop. The VirtualDub menu bar stops responding as well as the whole program. You can see the progress of the capture though, so it is processing. I have to go to the task manager to kill the app. I can capture using Windows Media Encoder just fine. Some other programs work too.
I have Zone alarm and Net Medic running in the tray. This is on a Win 2k Server with SQL installed. VirtualDub is version 1.4.13
cosworth
Posted: Dec 5 2002, 11:48 PM
And yes, the escape key has been pressed many times.
1 replies since Dec 5 2002, 06:17 PM Track this topic | Email this topic | Print this topic
