| User1 |
| Posted: Jun 9 2003, 10:02 PM |
Hi, I'm new here but have been using Vdub for a while now. I have version 1.5.4 and my problem is when you oen any video the coloring is way off - greens and purples appear on people's heads and all sorts of places. It's very weird because it works for a week, then it'll start doing this - it even occurs before encoding, and if I encode it in Xvid the output file is messed up in the same way. I really have to fix this. All videos, by the way, do this. |
| Posted: Jun 9 2003, 10:04 PM |
If you have the Angelpotion codec, remove it.
| User1 |
| Posted: Jun 9 2003, 10:08 PM |
I don't see it under my list of codecs in the compression window. This problem is weird, I'm not understanding what's going on. The normal video can't even be played correctly without changed to it. |
